Выберете то, что вам нужно
Rotate the Dash Cam to where the socket faces you.
Remove the 9 mm screw using the Torx T6 screwdriver.
Rotate the Dash Cam to where the product information faces you.
Remove the two 5 mm screws using the Torx T5 screwdriver.
Use the metal spudger to remove metal plate from device. This will reveal the screen.
Еще один человек закончил это руководство.
