Введение
This guide will show you how to properly remove the speaker from your Garmin without damaging the other components.
Выберете то, что вам нужно
Using a Torx T6 Screwdriver, remove the ten 7mm screws from the back panel.
Turn the device over, laying it on its back with the screen facing upwards.
Lift the front panel away from the silver part of the back panel.
Using the sharp end of the metal probe, scrape away the wax around the base of the speaker.
Slide the metal probe underneath the speaker and pry upwards.
Grasp the speaker wire near the motherboard and lift upward to detach the connector.
