Выберете то, что вам нужно
Turn the device screen down and using the screwdriver remove all eight screws from the back plate.
Place a nylon spudger in the seam between the front and back panel and carefully lift around the edge of the device.
Using the sharp side of the spudger, scrape away the adhesive surrounding the speaker.
Slide the spudger beneath the speaker and pull it away from the case.
Инструмент, используемый на этом этапе:Anti-Static Wrist Strap$7.95
Grasp the wire connecting the motherboard and pull the wares connecting it.
2 Комментариев
do u know where i can get a replacement speaker
