Введение
This guide will show you how to access, remove, and replace the battery of a Garmin Edge 530 device.
It may be necessary to replace the battery if the device is not turning on, or if the device has been damaged. You should troubleshoot to determine that the screen is operating properly before resorting to battery replacement.
The Garmin Edge 530 operates using a lithium-ion battery. This battery part can come as an individual battery or pre-packaged in a back case. If the part you order includes a back case, you should refer to the back case replacement guide for further instruction.
In this guide, you will have to pry up the glass panel with a metal spudger. It is important to note the potential broken glass hazard when prying the screen from the back cover. After this step, use ESD-safe tools to avoid damage to the rest of the device and protect it from electrostatic discharge.
A punctured battery can cause a fire. If the battery is swollen, it should be handled properly.
Before beginning, power down the device and disconnect from any external power sources.
Выберете то, что вам нужно
Insert the metal spudger between the edge of the device screen and back cover.
Begin to pry along the perimeter between the device screen and back cover.
Use the nylon halberd spudger to lift the edge of the screen and begin separating it from the back cover.
Peel back the tape holding down the orange ribbon cables with the nylon halberd spudger.
Completely detach the screen from the back cover by disconnecting the orange ribbon cables.
Detach the press-fit connector from the motherboard using the nylon halberd spudger.
Remove the three 6 mm screws connecting the motherboard to the back panel using the T5 Torx screwdriver.
Инструмент, используемый на этом этапе:Tweezers$3.99
Remove the wire harness that connects the motherboard to the battery using the angled tweezers by pulling it out of the compartment.
Use a nylon halberd spudger to pry up the orange ribbon cable connecting the battery to the charging port.
Fully remove the orange ribbon cable from the charging port.
Use the nylon halberd spudger to peel the battery from the adhesive holding it into the back case.
Gently pry up the edges of the battery.
Once the adhesive has been separated from the battery, carefully lift it out of the back case.
5 участников успешно повторили данное руководство.
3 Комментариев
How do those 3 cables get reattached? Do they need to be soldered or are they just pushed back into the black clip?
How do those 3 cables go back in, just push into bracket? Do they need to be soldered?
