Введение
Use this guide to replace a defective or broken internal LCD screen display for the Garmin Edge 530 (identified by part number 010-02060-00).
The LCD screen display assembly is made up of the glass panel (commonly thought of as the screen), a digitizer sheet, and the LCD component which utilizes a backlight to supply light which then passes through a crystal element to polarize the light and create pixels. The display may need to be replaced if the screen is cracked or broken, affecting the display assembly. Or, if the screen is remaining black or blank, indicating issues with connections to the display or components to the LCD itself.
In this guide, you will have to pry up the glass panel with a metal spudger. It is important to note the potential broken glass hazard when prying the screen from the back cover. After this step, use ESD-safe tools to avoid damage to the rest of the device and protect it from electrostatic discharge.
Выберете то, что вам нужно
Insert the metal spudger between the edge of the device screen and back cover.
Begin to pry along the perimeter between the device screen and back cover.
Use the nylon halberd spudger to lift the edge of the screen and begin separating it from the back cover.
Peel back the tape holding down the orange ribbon cables with the nylon halberd spudger.
Completely detach the screen from the back cover by disconnecting the orange ribbon cables.
To reassemble your device, follow these instructions in reverse order to attach the new LCD screen.
5 участников успешно повторили данное руководство.
2 Комментариев
Thanks for the instructions!
I didn't have a spudger, so I used a small knife instead.
For the assembly: when you put the new screen on the hardest part is the connection of the cable to the small socket of the back plate.
Also don't forget to put on some glue to the edges of the screen. In that way it stays better in place and is more water resistant.
worked well for me. Got screen off ebay from US seller. The glue was a little tough to get the old screen out. Ended up destroying it completely in the process, which was ok of course. Try to scrape as much of the old glue off as you can. New screen went in fine. Used a little glue to keep it in.
