Введение
cut off the mini-USB, or micro-USB, or Thunderbolt and remove the isolation of the red and the black wires.
the red wire will go on the top of the 4 contacts.
the black will go on the bottom last of the 4 contacts.
be creative and fasten them to the fenix 3. I used a clip and insulted it with a piece of plastic. you can also use duck take or similar to stick the 2 wires to the corresponding contacts on the fenix.
plug in the USB to a USB port or USB charging plug.
on the display you should now see the charging %
Выберете то, что вам нужно
11 участников успешно повторили данное руководство.
8 Комментариев
Thank you! You just saved my step streak :)
quiero que me cheque un garmin istinct que no recibe carga
