Введение
This guide will give you all the necessary steps to change your old motherboard for a new one.
Выберете то, что вам нужно
Use a plastic opening tool to remove the face of the device to expose the inner components.
Another ribbon is attached from the underside of the motherboard. Disconnect this ribbon.
The battery is glued to the motherboard and will need pried off with a nylon spudger.
5 участников успешно повторили данное руководство.
2 Комментариев
And where would one source replacement motherboard?
donde puedo encontras placa.madre reeemplazo????
