Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
If the buttons are unresponsive or sticking, the keypad may be compromised and need to be replaced. This is a guide to replace the keypad buttons of the Garmin GPSmap 60CSx.
Запчасти
Детали не указаны.
  1. Lift and twist the battery cover release  90 degrees counterclockwise on the back of the device.
    • Lift and twist the battery cover release 90 degrees counterclockwise on the back of the device.
  2. Lift battery release up to remove battery cover.
    • Lift battery release up to remove battery cover.
  3. Pull AA batteries out. Pull AA batteries out.
    • Pull AA batteries out.
  4. Remove the six 10 mm screws on the back of the device with a Phillips #0 screwdriver. Flip the back panel over to view the green electronics board (the PCB) and the PCB covering.
    • Remove the six 10 mm screws on the back of the device with a Phillips #0 screwdriver.
    • Flip the back panel over to view the green electronics board (the PCB) and the PCB covering.
    • Remove the black, yellow, blue, and red wires connected to the PCB with light force.
  5. Place the spudger in the bottom right corner of the black PCB cover and pry the corner out.
    • Place the spudger in the bottom right corner of the black PCB cover and pry the corner out.
    • The previous step will need to be done to the other three corners.
    • It is best to do the two bottom corners first.
    • Pull the black PCB board out of the GPSMap 60 CSx.
  6. Carefully use a spudger to lift the PCB a few centimeters. Pull the PCB out towards the bottom of the GPSMap 60CSx.
    • Carefully use a spudger to lift the PCB a few centimeters.
    • Pull the PCB out towards the bottom of the GPSMap 60CSx.
    • This will pull out all the main components including the antenna and the screen.
  7. Take the front panel and apply light force to the buttons. The buttons are part of one unit and should all pop out at once.
    • Take the front panel and apply light force to the buttons.
    • The buttons are part of one unit and should all pop out at once.
Заключение
2 участников успешно повторили данное руководство.
Thomas Humphrey
Участник с: 05.04.2018
534 Репутация
Автор 4 руководств
Команда
Linn Benton Community College, Team S2-G5, Johnson Spring 2018 Участник Linn Benton Community College, Team S2-G5, Johnson Spring 2018
LBCC-JOHNSON-S18S2G5
5 членов
Автор 5 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 6
За последние 30 дней: 28
За всё время: 1,588
