Введение
Prerequisite only: This guide will show you how to remove the frame of the Garmin Nuvi 1490T.
Выберете то, что вам нужно
Carefully insert the plastic prying tool into the crevice to separate the frame from the body.
Slide the plastic prying tool around the perimeter to completely remove the frame.
Remove the four 11.0 mm screws using the Torx T5 screwdriver.
Using the plastic prying tool, dislodge the frame from the body of the device.
Using your hands, completely disconnect the frame from the body.
Set the pieces of the frame aside.
Еще один человек закончил это руководство.
