Введение
Use this guide to replace your speaker for your Garmin Nuvi 1490T.
Выберете то, что вам нужно
Carefully insert the plastic prying tool into the crevice to separate the frame from the body.
Slide the plastic prying tool around the perimeter to completely remove the frame.
Remove the four 11.0 mm screws using the Torx T5 screwdriver.
Using the plastic prying tool, dislodge the frame from the body of the device.
Using your hands, completely disconnect the frame from the body.
Set the pieces of the frame aside.
Carefully move the display out of the way of the speaker revealing the blue and black cord from the speaker.
Using tweezers, gently clamp onto the white plastic end of the speaker connector.
Remove it by pulling slightly towards the speaker.
Wedge a nylon spudger into the crevice to begin to dislodge it from the body.
Slide the tool around the perimeter to fully dislodge the speaker.
