Garmin Nuvi 2557LMT Battery Replacement
Выберете то, что вам нужно
  1. Garmin Nuvi 2557LMT Battery Replacement, Garmin Nuvi 2557LMT Disassembly: шаг 1, изображение 1 из 1
    • Using a T5 Torx screwdriver, remove four 6 mm screws from the four corners of the back of the device.
  2. Garmin Nuvi 2557LMT Battery Replacement: шаг 2, изображение 1 из 1
    • Grip the device with your hands. Using your thumbs pull the nameplate towards yourself and off the device.
  3. Garmin Nuvi 2557LMT Battery Replacement: шаг 3, изображение 1 из 1
    • There is a visible separation between the front and the back of the device.
    • Using a plastic opening tool, pry open the device along this separation.
    • Trying to open the device on the opposite side will rip the motherboard-display connector.
  4. Garmin Nuvi 2557LMT Battery Replacement: шаг 4, изображение 1 из 2 Garmin Nuvi 2557LMT Battery Replacement: шаг 4, изображение 2 из 2
    • Carefully pull apart the device by opening it up on the opposite side of the nameplate.
  5. Garmin Nuvi 2557LMT Battery Replacement, Battery: шаг 5, изображение 1 из 1
    • Using a plastic opening tool pry the battery away from the device.
    • The battery might be glued, so it might require a little bit of force to get it out.
  6. Garmin Nuvi 2557LMT Battery Replacement: шаг 6, изображение 1 из 1
    • Pull the battery-motherboard connector away from the motherboard.
Заключение
2 участников успешно повторили данное руководство.
Danis Terzi
Участник с: 03/31/16
349 Репутация
Автор 3 руководств
Команда
Eastern Washington University, Team 1-3, Giguere Spring 2016 Участник Eastern Washington University, Team 1-3, Giguere Spring 2016
EWU-GIGUERE-S16S1G3
5 членов
Автор 5 руководств
2 Комментариев
On my Nuvi 2557, the silver name bezel is part of the front cover - it does not separate. I just split the case as shown.
The battery connector pulls out perpendicular to the pc board, and you re-insert it by aligning and pressing down against the board.
john horn - Ответить
Would this apply to the Nuvi 2555LMT?
Bill Hines - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 16
За всё время: 1,219
