Garmin Nuvi 2557LMT Motherboard Replacement
Выберете то, что вам нужно
  1. Garmin Nuvi 2557LMT Motherboard Replacement, Garmin Nuvi 2557LMT Disassembly: шаг 1, изображение 1 из 1
    • Using a T5 Torx screwdriver, remove four 6 mm screws from the four corners of the back of the device.
  2. Garmin Nuvi 2557LMT Motherboard Replacement: шаг 2, изображение 1 из 1
    • Grip the device with your hands. Using your thumbs pull the nameplate towards yourself and off the device.
  3. Garmin Nuvi 2557LMT Motherboard Replacement: шаг 3, изображение 1 из 1
    • There is a visible separation between the front and the back of the device.
    • Using a plastic opening tool, pry open the device along this separation.
    • Trying to open the device on the opposite side will rip the motherboard-display connector.
  4. Garmin Nuvi 2557LMT Motherboard Replacement: шаг 4, изображение 1 из 2 Garmin Nuvi 2557LMT Motherboard Replacement: шаг 4, изображение 2 из 2
    • Carefully pull apart the device by opening it up on the opposite side of the nameplate.
  5. Garmin Nuvi 2557LMT Motherboard Replacement, Battery: шаг 5, изображение 1 из 1
    • Using a plastic opening tool pry the battery away from the device.
    • The battery might be glued, so it might require a little bit of force to get it out.
  6. Garmin Nuvi 2557LMT Motherboard Replacement: шаг 6, изображение 1 из 1
    • Pull the battery-motherboard connector away from the motherboard.
  7. Garmin Nuvi 2557LMT Motherboard Replacement, Speaker: шаг 7, изображение 1 из 1
    • Using a plastic opening tool, wedge the speaker from the device.
    • Don't pull it out of the device too far. It is still connected to the motherboard wire.
  8. Garmin Nuvi 2557LMT Motherboard Replacement: шаг 8, изображение 1 из 1
    • Using a soldering iron, desolder the wire connection between the speaker and the device.
  9. Garmin Nuvi 2557LMT Motherboard Replacement, Motherboard: шаг 9, изображение 1 из 1
    • Using a T5 Torx Screwdriver, remove the 5mm screws in the four corners of the motherboard.
  10. Garmin Nuvi 2557LMT Motherboard Replacement: шаг 10, изображение 1 из 1
    • Using a plastic opening tool, pry the motherboard away from the device.
Заключение
Еще один человек закончил это руководство.
Danis Terzi
Участник с: 03/31/16
349 Репутация
Автор 3 руководств
Команда
Eastern Washington University, Team 1-3, Giguere Spring 2016 Участник Eastern Washington University, Team 1-3, Giguere Spring 2016
EWU-GIGUERE-S16S1G3
5 членов
Автор 5 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 8
За всё время: 446
