Введение
The tools you will need are a T5 Torx screwdriver, plastic opening tool, and soldering equipment. The speaker might be glued to the back of the device and is connected to the motherboard.
Выберете то, что вам нужно
Using a T5 Torx screwdriver, remove four 6 mm screws from the four corners of the back of the device.
Grip the device with your hands. Using your thumbs pull the nameplate towards yourself and off the device.
Carefully pull apart the device by opening it up on the opposite side of the nameplate.
Using a soldering iron, desolder the wire connection between the speaker and the device.
