Введение
Use this guide to replace the battery in the Garmin Nuvi 255W.
Выберете то, что вам нужно
Unscrew the four 6.70 mm screws holding the motherboard in place using a philips #0 screw driver.
Lift up the motherboard.
Carefully disconnect the battery and motherboard. Slowly wiggling the connection makes it easier to disconnect the battery from the motherboard.
Using the plastic opening tool as a wedge, pry the battery from the case. This can be fairly tough as the battery is glued to the case. Don't be afraid to use force and some good leverage.
15 участников успешно повторили данное руководство.
9 Комментариев
Thanks for the guide. Used it to open up a Nuvi 265 because the battery had been left to discharge below the protection circuit's limit. Connected the battery leads (Green = ground, Red = voltage, Black = temperature) to a 5v USB charger for ~20 seconds to revive the protection circuit, and the unit is now charging again. If you're going to do this, know the risks. Thermal runaways in lithium batteries can be extremely volatile.
