Введение
If your speaker is defective, obtain a new speaker and replace the old one with the new working speaker.
Выберете то, что вам нужно
Unscrew the four 6.70 mm screws holding the motherboard in place using a philips #0 screw driver.
Lift up the motherboard.
Carefully disconnect the battery and motherboard. Slowly wiggling the connection makes it easier to disconnect the battery from the motherboard.
Using the plastic opening tool as a wedge, pry the battery from the case. This can be fairly tough as the battery is glued to the case. Don't be afraid to use force and some good leverage.
Carefully disconnect the speaker from the motherboard. Slowly wiggling the connection makes it easier to disconnect.
Using a plastic opening tool, wedge the speaker away from the device. The speaker is glued to the case so use force and leverage.
