Введение
If your power button is not responding, use this guide to replace a defective power button on your Garmin NUVI 2589LMT device. Replacing the power button should fix any response issues you are experiencing with the button, but if it does not you may be experiencing a motherboard issue.
Выберете то, что вам нужно
Using the T5 Torx Screwdriver, remove all 4 of the 5.7mm screws from the back of the device.
Using the plastic opening tools, pry the shorter sides of the device apart.
Once a gap has formed at the top of the device, insert the opening tool into the gap and slide it along the top of the device. Repeat for the bottom edge of the device to separate the LCD screen from the back.
Using the angled tweezers, grip the red, black, and green wires connecting the battery to the motherboard, then gently lift away from the motherboard.
Using the angled tweezers, grab the microphone wires and gently pull to remove the microphone from the device.
Using the T5 Torx Screwdriver, remove all 4 of the 4.0 mm screws from the motherboard.
