Garmin Nuvi 2595LMT Digitizer Replacement
Выберете то, что вам нужно
  1. Garmin Nuvi 2595LMT Digitizer Replacement, Garmin Nuvi 2595LMT Back Cover Replacement: шаг 1, изображение 1 из 1
    • Place the device on the workspace so the screen is facing downward.
  2. Garmin Nuvi 2595LMT Digitizer Replacement: шаг 2, изображение 1 из 2 Garmin Nuvi 2595LMT Digitizer Replacement: шаг 2, изображение 2 из 2
    • Using the t5 screwdriver from the iFixit Pro Tool Kit, remove all four 5.6mm screws placing them safely on the table.
  3. Garmin Nuvi 2595LMT Digitizer Replacement: шаг 3, изображение 1 из 3 Garmin Nuvi 2595LMT Digitizer Replacement: шаг 3, изображение 2 из 3 Garmin Nuvi 2595LMT Digitizer Replacement: шаг 3, изображение 3 из 3
    • Grab a spudger from tool kit.
    • Pry open sides of Nuvi gently with spudger (do not rip apart).
    • Use plastic opening tool to pry ribbon slowly from white plastic bar.
    • Separate the two pieces and place them on the table
  4. Garmin Nuvi 2595LMT Digitizer Replacement, Digitizer: шаг 4, изображение 1 из 2 Garmin Nuvi 2595LMT Digitizer Replacement, Digitizer: шаг 4, изображение 2 из 2
    • Using the spudger, gently pry the sides of digitizer open until it lifts open and remove the digitizer from the LCD screen.
  5. Garmin Nuvi 2595LMT Digitizer Replacement: шаг 5, изображение 1 из 1
    • Heat the connection between the digitizer ribbon’s and LCD Screen's ribbon with a hot soldering to separate the two.
    • After the connection is seperated, place the digitizer screen on your work surface.
    • Take the replacement digitizer and place it over the top of the LCD screen.
    • Align the ribbon of the digitizer and lay it over the LCD ribbon.
    • Place the solder underneath the digitizer ribbon and above the LCD ribbon; the area you need to solder is silver and at the bottom of the LCD ribbon.
    • Using the soldering iron, heat up the solder and attach the two ribbons.
    • Let the solder cool for an hour.
    • The soldering iron will be hot. Be careful to not burn yourself.
Заключение
Еще один человек закончил это руководство.
Taylor DeWitt
Участник с: 01/06/16
538 Репутация
Автор 4 руководств
Команда
Eastern Washington University, Team 2-2, Andersen Winter 2016 Участник Eastern Washington University, Team 2-2, Andersen Winter 2016
EWU-ANDERSEN-W16S2G2
5 членов
Автор 6 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 13
За всё время: 1,556
