Введение
Use this guide to replace the LCD Screen of your Garmin Nuvi 2595LMT GPS.
Выберете то, что вам нужно
Place the device on the workspace so the screen is facing downward.
Using the t5 screwdriver from the iFixit Pro Tool Kit, remove all four 5.6mm screws placing them safely on the table.
Grab a spudger from tool kit.
Pry open sides of Nuvi gently with spudger (do not rip apart).
Use plastic opening tool to pry ribbon slowly from white plastic bar.
Separate the two pieces and place them on the table
Grabbing the top half of the Nuvi, remove the screen from the tabs holding it in place using thumbs.
Place screen on table.
2 участников успешно повторили данное руководство.
3 Комментариев
cannot prise open the connector to replace ribbon
My screen is cracked. The screen opens, but I can't use the key board.
Thank You For any Help You Can Give Me,
Cookie
cookiecaafato1@yahoo.com nuvi 2595 LMT
