Запчасти
Детали не указаны.
  1. Remove PN/Model sticker an the lower side of the device.
    • Remove PN/Model sticker an the lower side of the device.
    • Use pentalobe screwdriver to remove the two screws underneath it.
    • Use the nylon spudger to remove the screen from the device.
    • The regular black nylon spudger should be used whenever possible, especially around glass displays and other sensitive components.
  2. Lift up the screen gently and place it on the opposite side.
    • Lift up the screen gently and place it on the opposite side.
  3. Use a plastic opening tool to gently lift up the white rectangular snap clip that is attached to the screen.
    • Use a plastic opening tool to gently lift up the white rectangular snap clip that is attached to the screen.
  4. Lift up the screen and you're done.
    • Lift up the screen and you're done.
Заключение
Patricia Gonzalez
Участник с: 10.10.2016
337 Репутация
Автор 3 руководств
Команда
Texas Tech, Team 6-4, Bennett Fall 2016 Участник Texas Tech, Team 6-4, Bennett Fall 2016
TTU-BENNETT-F16S6G4
4 членов
Автор 4 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 4
За всё время: 326
