Garmin Nuvi 2797LMT Battery Replacement
Выберете то, что вам нужно
  1. Garmin Nuvi 2797LMT Battery Replacement, Battery: шаг 1, изображение 1 из 1
    • Before you begin make sure to turn off your GPS.
    • Using your T-6 Torx Screwdriver, unscrew the ten 2.38 mm torx T-6 screws from the back of your GPS.
  2. Garmin Nuvi 2797LMT Battery Replacement: шаг 2, изображение 1 из 3 Garmin Nuvi 2797LMT Battery Replacement: шаг 2, изображение 2 из 3 Garmin Nuvi 2797LMT Battery Replacement: шаг 2, изображение 3 из 3
    • Using the biggest plastic opening tool, pry open the GPS from the sides. You should now be able to see everything inside the GPS.
    • Be careful when opening the GPS because of the ribbon attached to the screen. It can tear easily.
  3. Garmin Nuvi 2797LMT Battery Replacement: шаг 3, изображение 1 из 2 Garmin Nuvi 2797LMT Battery Replacement: шаг 3, изображение 2 из 2
    • With the device open, locate the battery with its wire connector plugged into the motherboard. Now delicately detach the battery connector from the center by inserting a spudger underneath the power wire and lift up.
  4. Garmin Nuvi 2797LMT Battery Replacement: шаг 4, изображение 1 из 1
    • Now using the small plastic opening tool, pry the battery up from the sides.
    • The battery has been attached with strong adhesive so you will need to use a little bit of force when prying it out.
Заключение
Еще один человек закончил это руководство.
baileykaytar
Участник с: 10/13/15
366 Репутация
Автор 2 руководств
Команда
Sam Houston State, Team 2-6, Blackburne Fall 2015 Участник Sam Houston State, Team 2-6, Blackburne Fall 2015
SHSU-BLACKBURNE-F15S2G6
3 членов
Автор 4 руководств
3 Комментариев
Your sub-par tools broke when following the directions exactly. Last time I'll be purchasing any of your items, and Ill be disputing the charges on my card for this kit.
Game Science - Ответить
Thanks.
But before I get going, which model or type of battery do I need. Garmin does not seem to sell them separately as far as I can see.
GregM
cagmccarry2 - Ответить
Instructions very lacking. To replace the battery go to https://www.youtube.com/watch?v=OcoZC2Fk.... Much, much better instructions.
allen1 - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 13
За всё время: 2,342
