Введение
This guide instructs how to replace a faulty speaker.
Выберете то, что вам нужно
Place the LCD screen is face down on a flat surface.
Make sure the side containing the speaker and the charging port is facing up.
Remove the four 9 mm screws on the back of the GPS unit using the Torx T-4 screwdriver found in the iFixit Pro Tech Tool Kit.
Gently pry open the device with the iFixit Plastic Opening Tool found in the iFixit Pro Tech Tool Kit.
Once the GPS is open, identify the black and blue wires connecting the black speaker to the green motherboard.
The black wire is located closest to the speaker.
The blue wire is located farthest from the speaker.
Solder the wires of the replacement speaker back onto the small silver squares located on the motherboard using the iFixit Soldering Station.
Еще один человек закончил это руководство.
