Garmin Nuvi 680 Battery Replacement
Выберете то, что вам нужно
  1. Garmin Nuvi 680 Battery Replacement, Outer Case: шаг 1, изображение 1 из 1
    • Flip open the antenna on the back of the device.
    • Remove the two 4.42 mm screws on the antenna cover using a T5 Torx screwdriver.
  2. Garmin Nuvi 680 Battery Replacement: шаг 2, изображение 1 из 1
    • Remove the antenna cover.
  3. Garmin Nuvi 680 Battery Replacement: шаг 3, изображение 1 из 1
    • The yellow wire is connected to the motherboard, so you cannot disconnect it until you finish opening the device.
    • Pull the antenna circuit board out of its case.
  4. Garmin Nuvi 680 Battery Replacement: шаг 4, изображение 1 из 2 Garmin Nuvi 680 Battery Replacement: шаг 4, изображение 2 из 2
    • Insert the pointed end of a spudger into the leftmost slit of the antenna case.
    • Push the spudger to the right.
    • Slide the antenna case out slowly or you may lose the antenna's spring. The spring is inside the black plastic that holds the antenna case to the device.
    • Slide the antenna case out of the device.
    • Reinstallation tip: first reassemble the antenna casing (place antenna back into its plastic cover), and then re-insert the entire assembly back into the GPS body.
  5. Garmin Nuvi 680 Battery Replacement: шаг 5, изображение 1 из 1
    • Remove the two screws on the back of the outer case using a T5 Torx screwdriver.
    • These screws are 10.82 mm long.
  6. Garmin Nuvi 680 Battery Replacement: шаг 6, изображение 1 из 2 Garmin Nuvi 680 Battery Replacement: шаг 6, изображение 2 из 2
    • Gently pull apart the front and back of the device. The front and back are still connected by ribbon cables.
    • Starting along the top, separate the front and back of the device by pushing an iPod-opening tool into the crack along each side of the case.
  7. Garmin Nuvi 680 Battery Replacement, Antenna: шаг 7, изображение 1 из 2 Garmin Nuvi 680 Battery Replacement, Antenna: шаг 7, изображение 2 из 2
    • Use a spudger to disconnect the yellow antenna wire from the ZIF connector by opening the brown latch holding the wire in place.
    • Remove the antenna.
  8. Garmin Nuvi 680 Battery Replacement, Screen Wiring: шаг 8, изображение 1 из 1
    • Do not remove the ribbon cables without lifting the latch or the cable will be damaged.
    • Lift the latches on the ribbon cable connectors. All the ribbon cables may have latches. The right most latch may have a latch that flips in the opposite direction from the others.
    • Gently pull the ribbon cables out of their connectors. They should slide out easily.
    • Do not separate the two halves of the device yet or the on/off cable may be severed.
  9. Garmin Nuvi 680 Battery Replacement: шаг 9, изображение 1 из 2 Garmin Nuvi 680 Battery Replacement: шаг 9, изображение 2 из 2
    • Gently pull the cable for the on/off button straight up to remove it.
    • The two halves of the device may now be separated.
  10. Garmin Nuvi 680 Battery Replacement, Motherboard: шаг 10, изображение 1 из 1
    • Use a PH1 sized Philips screwdriver to remove the two screws shown.
    • These screws are 6.88 mm long
  11. Garmin Nuvi 680 Battery Replacement: шаг 11, изображение 1 из 2 Garmin Nuvi 680 Battery Replacement: шаг 11, изображение 2 из 2
    • Carefully separate the motherboard from the outer case or the speaker and battery cables may be damaged.
    • Use a spudger to lift the edge of the motherboard.
  12. Garmin Nuvi 680 Battery Replacement: шаг 12, изображение 1 из 1
    • Gently unplug the cable for the battery
    • Gently unplug the cable for the speaker.
  13. Garmin Nuvi 680 Battery Replacement: шаг 13, изображение 1 из 1
    • Lift the motherboard out of the outer case.
  14. Garmin Nuvi 680 Battery Replacement, Battery: шаг 14, изображение 1 из 2 Garmin Nuvi 680 Battery Replacement, Battery: шаг 14, изображение 2 из 2
    • The battery is difficult to remove because it's glued to the case.
    • Use a spudger to gently pry the battery out of its slot.
    • Remove the battery.
Заключение
2 участников успешно повторили данное руководство.
Chris Marzano
Участник с: 01/20/11
968 Репутация
Автор 6 руководств
Команда
Cal Poly, Team 5-22, Amido Winter 2011 Участник Cal Poly, Team 5-22, Amido Winter 2011
CPSU-AMIDO-W11S5G22
5 членов
Автор 7 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 11,495
