Введение
If you need to replace the Garmin STRIKER 4 motherboard, access it with this guide. Some reasons you may be replacing the motherboard include button sensors not working or last-resort fixes to other problems with the screen and readings. Be careful when prying away the old motherboard to avoid any further damage to the casing.
Выберете то, что вам нужно
Remove all six 6 mm screws using a Phillips #0 screwdriver.
Detach and flip the backside to open the device.
Slide out the screen cable from the motherboard using the iFixit opening tool or your fingernail.
Remove the motherboard from the device.
