Введение
Before you begin disassembling the device, be sure the power is off.
Выберете то, что вам нужно
Wedge a plastic opening tool in between the outer frame and the rear panel assembly.
Pry the outer frame off the perimeter of the rear panel assembly.
Remove the four #00 Phillips screws securing the front case assembly to the rear case assembly.
Carefully lift, but do not completely separate, the front case assembly from the rear case assembly.
Gently pull the battery cable connector from its socket on the motherboard.
The second connector can remain attached to the motherboard, but be careful not to break the connector while handling both halves of the device.
