Введение
The circuit board and its components are delicate, so use caution when disassembeling.
Выберете то, что вам нужно
Turn the device off by pressing and holding the power button on the top left of the device.
Use the plastic opening tool to separate the tabs on the black back cover of the device by leveraging the tool against the frame around the perimeter of the device.
Using the plastic spudger, carefully remove the white tab connected to the battery from the device by pulling the tab in the opposite direction from which it is connected.
Using the T5 bit, unscrew the four 5.7mm screws in the four corners of the device.
Leverage the plastic opening tool to pop the tabs between the black screen and the metal frame around the perimeter of the device.
Locate the red and black wire connected to the logic board with the round, black, rubber disc that connects to the other half of the device. Gently pull the wire up from the logic board.
Separate the connection between the speaker and the logic board by gently pulling the wire up.
Using the J000 bit, unscrew the four 4.0 mm screws from the corners of the logic board.
Starting near the power button, leverage the spudger to pry up the logic board around the perimeter of the frame.
Еще один человек закончил это руководство.
