Введение
removal of the system board
Выберете то, что вам нужно
Flip the laptop over.
Slide the battery release tab to the right with your index finger to open the battery cover.
Remove the battery cover using the tab on the right side.
Take the battery out with your index finger.
Slide the release and push the button to eject the drive.
Remove the drive.
Unscrew 1 captive screw holding hard drive cover on.
slide hard drive to the right and remove.
for detailed pictures and info go to Gateway Support
Insert the spudger between the "sysrq" and "ins" keys.
Gently pry free the power button panel above the keyboard, beginning from the right and moving to the left.
Remove the five screws with a Phillips #0 screwdriver.
Lift the hinge covers along the outer edges with the spudger until they are released.
Using the Phillips #0 screwdriver, remove six screws that hold the LCD to the hinge.
Unscrew the four captive screws.
Unplug the fan from the system and pull it out. The fan unit should slide forward before coming free.
Use a Phillips #0 screwdriver to remove the thirteen screws from the bottom of the computer.
Lift the plug holding the mouse ribbon about 1/16 inch or until it stops
Remove the ribbon.
Insert your spudger between the upper and lower case at the drive bay closest to the battery.
Carefully and slowly go around the entire case, unseating all plastic clips holding the upper and lower cases together.
Lift the upper case about 1/4 inch.
At the rear of the case is one last connecting wire. Unplug it and remove the upper case.
Remove 4 screws holding left speaker for ease of access to connectors and external sound board.
Remove screw and unplug speakers from external sound board.
Lift external soundboard away from system board and remove.
Unplug audio DJ
Unplug System status light board
Starting on the right side of case gently lift and slide system board till it comes free of lower case.
