Выберете то, что вам нужно
Turn the laptop over so the bottom of the device is facing upwards with the hinge facing away from you.
Locate the switch on the top left of the laptop labeled with a padlock symbol.
Flip the switch in the direction of the unlocked padlock symbol.
Use the small spudger to slide the cable lock up on both sides of the connector and slide the cable out
2 участников успешно повторили данное руководство.
