Выберете то, что вам нужно
Turn the laptop over so the bottom of the device is facing upwards with the hinge facing away from you.
Locate the switch on the top left of the laptop labeled with a padlock symbol.
Flip the switch in the direction of the unlocked padlock symbol.
Use the Small metal spudger to remove the small black screw covers in the bottom corners of the screen
Use the small metal spudger to start separating the front plastic cover from the back plastic cover
Once there is enough room for you to fit your hand underneath the top plastic cover you can start pealing it back. It will make a lot of popping noises as it unclips when you separate it.
Once the plastic cover is off locate the 4 screws in the corners of the screen and unscrew them
Инструмент, используемый на этом этапе:Tweezers$4.99
Use the tweezers to peal back the tape over the wire connector on the bottom of the screen
2 человек успешно провели ремонт по этому руководству.
