Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Unlock the tab located in the top left corner of the netbook.
The red tab indicated that the battery has been properly unlocked.
Remove the battery.
Remove the two (2) 5mm screws holding the cover down using the Phillips #0 screwdriver.
Using a Phillips #0 screwdriver, remove a third 5mm screw that holds the second cover that is directly protecting the hard drive.
Slide the silver cover up; the hole on the cover and the hole for the screw will no longer match up.
Lift the silver cover; this will expose the hard drive.
