Введение
Keys are easy to replace on a Gateway netbook. You can purchase keys online at Amazon, eBay, or the product page. Keys contain three parts: key cap, key retainer clip, and rubber cup. For this guide, we will replace the key cap.
Запчасти
Никакие детали не требуются.
Before replacing any key, make sure your netbook is turned off to prevent any mistakes during the process.
  • Before replacing any key, make sure your netbook is turned off to prevent any mistakes during the process.
Добавить комментарий
Insert a plastic opening tool under the key to be removed. Insert a plastic opening tool under the key to be removed.
  • Insert a plastic opening tool under the key to be removed.
Put the opening tool underneath the key. Use force until the key pops up.
  • Put the opening tool underneath the key. Use force until the key pops up.
  • To replace the key, follow these instructions, but do them in reverse order (i.e., use the plastic opening tool to put the key back in place).
Заключение
My Linh Pham
301 Репутация
Автор 3 руководств
Команда
UMass Dartmouth, Team 3-2, Calaway Spring 2014 Member of UMass Dartmouth, Team 3-2, Calaway Spring 2014
UMASSD-CALAWAY-S14S3G2
4 членов
Автор 18 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 0
За всё время: 230
