Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
The RAM can be replaced if you have a Phillips #0 screwdriver.
Выберете то, что вам нужно
Unlock the tab located in the top left corner of the netbook.
The red tab indicated that the battery has been properly unlocked.
Remove the battery.
Using a Phillips #0 screwdriver, remove one (1) 5mm screw holding the cover in place.
Use a plastic opening tool to remove the cover.
Unlock the RAM by pinching the metal clamps that keep the RAM in place.
Remove the RAM while the metal clamps are disengaged.
