Запчасти
Никакие детали не требуются.
Unlock the button in the top left on the back of the laptop (So the red is showing).
  • Unlock the button in the top left on the back of the laptop (So the red is showing).
Добавить комментарий
The battery should be able to be removed easily now.
  • The battery should be able to be removed easily now.
The RAM is located under this cover.
  • The RAM is located under this cover.
Using a Phillips #0 screwdriver, remove one (1) 5mm screw holding the cover in place. Use a plastic opening tool to remove the cover. Try opening tools of different sizes to find one that will easily open the cover. Use a plastic opening tool to remove the cover. Try opening tools of different sizes to find one that will easily open the cover.
  • Using a Phillips #0 screwdriver, remove one (1) 5mm screw holding the cover in place.
  • Use a plastic opening tool to remove the cover. Try opening tools of different sizes to find one that will easily open the cover.
Unlock the RAM by pinching the metal clamps that keep the RAM in place. Remove the RAM while the metal clamps are disengaged. Use two opening tools, positioned on each side of the RAM, and push outwards to remove the RAM.
  • Unlock the RAM by pinching the metal clamps that keep the RAM in place.
  • Remove the RAM while the metal clamps are disengaged. Use two opening tools, positioned on each side of the RAM, and push outwards to remove the RAM.
Заключение
Emily
Участник с: 11.03.2014
301 Репутация
Автор 3 руководств
Команда
UMass Dartmouth, Team 3-2, Calaway Spring 2014 Member of UMass Dartmouth, Team 3-2, Calaway Spring 2014
UMASSD-CALAWAY-S14S3G2
4 членов
Автор 18 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 2
За всё время: 105
