Gateway KAV60 LT2016U Webcam Replacement
Выберете то, что вам нужно
  1. Gateway KAV60 LT2016U Webcam Replacement, Battery: шаг 1, изображение 1 из 3 Gateway KAV60 LT2016U Webcam Replacement, Battery: шаг 1, изображение 2 из 3 Gateway KAV60 LT2016U Webcam Replacement, Battery: шаг 1, изображение 3 из 3
    • Unlock the tab located in the top left corner of the netbook.
    • The red tab indicated that the battery has been properly unlocked.
    • Remove the battery.
    • When working with electronics, it is always wise to remove the power source before taking the device apart.
  2. Gateway KAV60 LT2016U Webcam Replacement, Upper Cover: шаг 2, изображение 1 из 1
    • Make sure the RAM, hard drive, and WiFi card have been removed from the computer before trying to take off the cover so they are not damaged in the process.
  3. Gateway KAV60 LT2016U Webcam Replacement: шаг 3, изображение 1 из 2 Gateway KAV60 LT2016U Webcam Replacement: шаг 3, изображение 2 из 2
    • Remove six (6) 5mm screws, two (2) 17.5mm screws, and three (3) 2.5mm screws from the back, using the Phillips #0 screwdriver, as marked here.
  4. Gateway KAV60 LT2016U Webcam Replacement: шаг 4, изображение 1 из 3 Gateway KAV60 LT2016U Webcam Replacement: шаг 4, изображение 2 из 3 Gateway KAV60 LT2016U Webcam Replacement: шаг 4, изображение 3 из 3
    • Pry up the keyboard using a spudger or plastic opening tool in the exact location shown in the photograph.
    • Don't use a screwdriver as a pry tool as shown in this example.
    • Carefully disconnect the keyboard ribbon cable from the motherboard, and remove the keyboard.
  5. Gateway KAV60 LT2016U Webcam Replacement: шаг 5, изображение 1 из 1
    • Remove the five (5) 5mm screws shown here using the Phillips #0 screwdriver.
  6. Gateway KAV60 LT2016U Webcam Replacement: шаг 6, изображение 1 из 2 Gateway KAV60 LT2016U Webcam Replacement: шаг 6, изображение 2 из 2
    • Separate the upper cover from the back cover. It is possible to do this without a tool, but you may also use a plastic opening tool for added leverage.
    • Be careful to keep even pressure all the way around the cover so that it is not bent beyond repair.
    • Carefully disconnect two ribbon cables to complete the separation of the upper cover.
  7. Gateway KAV60 LT2016U Webcam Replacement, LCD: шаг 7, изображение 1 из 3 Gateway KAV60 LT2016U Webcam Replacement, LCD: шаг 7, изображение 2 из 3 Gateway KAV60 LT2016U Webcam Replacement, LCD: шаг 7, изображение 3 из 3
    • Pry the border around the monitor off of the top cover using a plastic opening tool, as shown.
    • Be careful not to damage the computer screen in the process
  8. Gateway KAV60 LT2016U Webcam Replacement: шаг 8, изображение 1 из 2 Gateway KAV60 LT2016U Webcam Replacement: шаг 8, изображение 2 из 2
    • Separate the monitor from the border cover once all snap connections have been pried apart.
  9. Gateway KAV60 LT2016U Webcam Replacement: шаг 9, изображение 1 из 1
    • Remove the six (6) 5mm screws shown here using the Phillips #0 screwdriver.
  10. Gateway KAV60 LT2016U Webcam Replacement: шаг 10, изображение 1 из 2 Gateway KAV60 LT2016U Webcam Replacement: шаг 10, изображение 2 из 2
    • Take the screen out of the top cover.
  11. Gateway KAV60 LT2016U Webcam Replacement, Webcam: шаг 11, изображение 1 из 2 Gateway KAV60 LT2016U Webcam Replacement, Webcam: шаг 11, изображение 2 из 2
    • The webcam is located here, as shown.
    • Disconnect the webcam from the wires attaching it to the computer.
    • Lift the webcam away from the top cover.
Заключение
Lydia Benjock
Участник с: 10/18/13
1 216 Репутация
Автор 10 руководств
Команда
Clemson, Team 14-3, Benson Fall 2013 Участник Clemson, Team 14-3, Benson Fall 2013
CLEM-BENSON-F13S14G3
3 членов
Автор 22 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 516
