Введение
The WiFi card can be replaced once you've opened up your computer.
Инструменты
Запчасти
Детали не указаны.
Unlock the tab located in the top left corner of the netbook.
The red tab indicated that the battery has been properly unlocked.
Remove the battery.
Remove six (6) 5mm screws, two (2) 17.5mm screws, and three (3) 2.5mm screws from the back, using the Phillips #0 screwdriver, as marked here.
Pry up the keyboard using a spudger or plastic opening tool in the exact location shown in the photograph.
Carefully disconnect the keyboard ribbon cable from the motherboard, and remove the keyboard.
Separate the upper cover from the back cover. It is possible to do this without a tool, but you may also use a plastic opening tool for added leverage.
Be careful to keep even pressure all the way around the cover so that it is not bent beyond repair.
Carefully disconnect two ribbon cables to complete the separation of the upper cover.
The WiFi card is shown here.
Remove the one (1) 5mm screw holding the card to the motherboard using a Phillips #0 screwdriver.
Disconnect the wires on the WiFi card. This can be done easily by applying pressure to the connections until they pop off of the card.
3 участников успешно повторили данное руководство.
