Введение
In any computer repair, removing the power source will prevent many dangerous situations. It should be the first thing you do whenever you want to make any repair or replacement.
Place the laptop upside down on a flat surface so you can see the battery.
While keeping both of the tabs in the unlocked position, grab the battery and pull outwards, until the battery slides out from the rest of the computer.
To put the battery back, just slide it back into its slot and make sure that both locking tabs are locked.
