Введение
If you need to have access to the inner workings of your laptop in order to replace some parts, this guide will help you to remove the panels to access them.
Выберете то, что вам нужно
Using the Phillips #1 screwdriver, remove the four 6mm screws on the back of the laptop.
Insert the plastic prying tool and pry the back panel off starting at an edge and moving your way around it.
Почти готово!
Заключение
