Введение
The battery is probably the most commonly replaced part because over time battery life diminishes. Replacing the battery with a new one will rejuvenate battery life.
Turn the laptop over so that the underside is facing towards you.
Slide the long slider towards the unlocked lock icon.
This slider is spring loaded and may require a little force.
If done correctly, a click will be heard and the battery will be slightly raised.
