Введение
This guide shows the user how to properly remove the RAM from the Gateway MS2370 Laptop.
Выберете то, что вам нужно
Make sure the laptop is turned off and flipped over so that the bottom is facing up. Then, locate the battery clip as shown.
Either using your fingers or a plastic spudger push the battery clip to the left to release battery.
Unscrew the rest of the case screws which include several 10mm 01 Phillips screws and three 3mm 00 Phillips screws.
This marked screw will not fully come out. Just loosen it and leave it there it will not effect the rest of the replacement.
Unplug the track-pad and the keyboard ribbon cable by lifting up the grey flap and removing the cable.
Unplug the ribbon cable connected to the USB Hub, the network card, and the monitor cable.
Using your two thumbs to pull outwards from the inside of the RAM slot to release and remove the RAM.
2 участников успешно повторили данное руководство.
