Введение
If you can't connect to a wireless internet signal, a faulty wireless card is most likely the problem and you’ll have to replace it with a functioning one. This guide will provide you with the steps necessary to replace your old wireless card with a new one, so you can get back to surfing the web!
Выберете то, что вам нужно
Remove 18 6.0 mm Phillips #00 screws from the bottom of the laptop.
Remove 5 6.0 mm Phillip #00 screws from under cover.
Separate the bottom panel from the touchpad assembly by inserting a plastic opening tool between them on all four sides.
Pull black ribbon wire from port using tweezers in order to completely separate touchpad assembly from bottom assembly.
Disconnect the two ZIF ports that attach the touchpad assembly to the motherboard.
First flip open the flap covering the ribbon using a spudger or fingernail.
Second gently pull the ribbon away from the port.
Remove the one 2.9 mm Phillips #00 screw holding down the wireless card in place.
After the screw is removed, the card will spring upwards slightly. Pull out the old wireless card from its port.
