Введение
Is your computer experiencing significant problems with loading or booting up in general? Consider using this guide to replace the motherboard of your device. This guide will walk you through removing the motherboard, but when you remove the motherboard the fan will also be attached.
Выберете то, что вам нужно
Slide the tab to the left and hold the tab there.
While holding down the sliding tab, remove the battery from the device.
After removing the battery, remove 15 7mm screws using the Phillip #1 Screwdriver.
Lift the upper case cover off of the device. Use a prying tool along the edges if necessary.
