Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Remove the five identical 3/16" Phillips screws that secures the hard drive and memory cover using a Phillips #0 Screwdriver.
Lift up the base cover from the the top with your hands to a 90 degree angle.
Remove the base cover and place it in a safe and dry place.
Remove the 1/4" Phillip screw located at the top right of the Hard Drive using a Phillips #0 Screwdriver .
Remove the Hard Drive component from its compartment. To do so, slide the component downward away from the battery pack.
Lift the Hard Drive to a 90 degree angle and out of its slot.
Place the Hard Drive in a designated zone.
2 участников успешно повторили данное руководство.
