Выберете то, что вам нужно
Use a spudger to gently pry out the keyboard.
There are small metal tabs holding it in place beneath the bezel. Using your tool, you should be able to easily pop the keyboard out.
Once the keyboard is removed, you may have to remove the connecting ribbon cable, but it easily pulls out.
Еще один человек закончил это руководство.
