Введение
Both the battery and rear cover guides should be completed before completing this guide. This guide can be used for replacing a dying hard drive or upgrading your current hard drive.
Запчасти
No parts specified.
  1. Push orange locking tab with spudger right,  until battery lifts out of place. Laptop should be unplugged from power supply before removal. Laptop should be unplugged from power supply before removal.
    • Push orange locking tab with spudger right, until battery lifts out of place.
    • Laptop should be unplugged from power supply before removal.
  2. Unscrew the two  7 mm long #0 Phillips screws.
    • Unscrew the two 7 mm long #0 Phillips screws.
  3. iPhone Battery Fix Kits
    Only $29.99
    Buy Now
    Only $29.99
    Buy Now
  4. Lift and remove the cover panel via the indentation in the middle of the panel.
    • Lift and remove the cover panel via the indentation in the middle of the panel.
  5. Push spudger to the left until hard drive is moved from its original position.
    • Push spudger to the left until hard drive is moved from its original position.
  6. Pull plastic flap and pull hard drive away from laptop.
    • Pull plastic flap and pull hard drive away from laptop.
Заключение
Aaron Allison
Участник с: 05.11.2018
433 Репутация
Автор 5 руководств
Команда
IUPUI, Team S1-G1, Baechle Fall 2018 Member of IUPUI, Team S1-G1, Baechle Fall 2018
IUPUI-BAECHLE-F18S1G1
3 членов
Автор 5 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 3
За всё время: 83
