Введение
This guide will teach you how to remove your laptop's RAM. Upgrading RAM is a common practice.
Выберете то, что вам нужно
Use the J0 screwdriver to remove the five 2mm screws holding the back plate.
Push the upper RAM module's two pins outwards at the same time.
If done correctly, the module should lift.
Push the lower RAM module's two pins outwards at the same time.
If done correctly, the module should have lifted.
Почти готово!
Заключение
