Введение
The batteries power the car and allow it to run. If it isn't running, try using the following steps to replace the batteries.
Запчасти
No parts specified.
  1. Remove the 5mm Phillips #0 screw from the bottom of the car, located between the rear wheels. Gently lift the battery cover from the car to expose the batteries. Gently lift the battery cover from the car to expose the batteries.
    • Remove the 5mm Phillips #0 screw from the bottom of the car, located between the rear wheels.
    • Gently lift the battery cover from the car to expose the batteries.
Заключение
Claudia Robinson
Участник с: 01.02.2015
419 Репутация
Автор 3 руководств
Команда
Cal Poly, Team 8-38, Amido Winter 2015 Member of Cal Poly, Team 8-38, Amido Winter 2015
CPSU-AMIDO-W15S8G38
4 членов
Автор 8 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 3
За всё время: 271
