Введение
This guide will explain how to replace the power supply cable of the General Electric Bagel Switch 4-Slice toaster.
Выберете то, что вам нужно
Look for the plastic clips on the back side of the toaster.
Disconnect the small plastic clips on the back of the toaster. Use Philips head Screwdriver to do this step.
Now, carefully remove the toaster casing.
Carefully separate the bottom plate from the metal components inside the toaster.
Using wire cutters, cut the power supply cable close to the base of the toaster, leave about 2 inches of wire.
Insert the end of the new power supply cable through the hole in the bottom plate.
Strip about an inch of the wire insulation (casing) off the ends of both the new power supply cable, and the old power supply cable that is still attached to the toaster.
