Введение
This guide will demonstrate how to remove the LCD screen and replace it with a new one.
Выберете то, что вам нужно
Begin by removing the 5 screws (located: 2 screws on either side and 1 screw on the bottom) using the PH000 head in the Precision Phillips Screwdriver.
After the screws are removed, pull the front casing up and away from the camera.
Using your hands or an opening tool, pry off the silver frame, taking special care at the top of the camera where the buttons are as it is a little harder to pry off.
The last part of the casing to disconnect is the back that houses the LCD screen.
The screen is attached by a connection ribbon. Gently pull the casing and screen away from the camera body to disconnect the casing.
With the back casing that you just separated from the camera, use your finger to push the LCD screen from the frame.
Еще один человек закончил это руководство.
