Введение
Use this guide to replace the reverse switch on a General Pipe Cleaners Drain Cleaner EJB 2014.
Выберете то, что вам нужно
Use a Phillips #2 driver to remove the two screws securing the control box cover.
Use a 9/16 inch deep socket and ratchet to remove the nut securing the reverse switch.
Squeeze the tabs on either side of the reverse switch connector.
Pull the two halves of the connector apart to disconnect it.
Pull the white cable straight off of its spade connector on the power switch diaphragm.
Pull the black cable straight off of its spade connector on the power switch diaphragm.
Slide the switch assembly down out of its hole in the control box and pull it out of the control box.
Be careful not to snag the switch on any cables during removal.
2 участников успешно повторили данное руководство.
