Введение
Use this guide to replace the power cable in a General Pipe Cleaners Drain Cleaner PMEBO 2016.
Выберете то, что вам нужно
Use a Phillips #2 driver to remove the two screws securing the control box cover.
Use a 9/16 inch deep socket and ratchet to remove the nut securing the reverse switch.
Squeeze the tabs on either side of the reverse switch connector.
Pull the two halves of the connector apart to disconnect it.
Pull the white cable straight off of its spade connector on the power switch diaphragm.
Pull the black cable straight off of its spade connector on the power switch diaphragm.
Slide the switch assembly down out of its hole in the control box and pull it out of the control box.
Push in on the small tab on the side of the plastic power cable clip.
While holding the tab down, pull straight down on the power cable.
Use a Phillips #2 screwdriver to loosen the two screws securing the power box cover.
With the screws loose, slide the bottom of the cover to the right enough so the whole cover can swing down and away from the box opening.
Use a flathead screwdriver to remove the green screw securing the green power cable wire.
Feed the green power cable wire through the control box first, then carefully pull down on the entire power cable and remove it.
2 участников успешно повторили данное руководство.
