Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Pull out and rotate the quick release lever until the axle is loose.
Pull back on the derailleur on the left hand side. This lessens the force required to remove the wheel from its mount greatly.
Lift the bike, and pull the wheel from its mount.
Use a flat head screwdriver to push out on the break pads in order to space the hydraulic pistons.
Slide the cover off of the hydraulic port until it is fully exposed.
Use a torque head bit to remove the screw on the hydraulic port of the brake handle. Be careful to not lose this screw.
Use a torque spit to remove the indicated screw on the rear brake caliper.
Fill your syringe with hydraulic fluid.
Clear air out of the syringe by holding it upright, flicking on it with your finger, and pushing on the stopper until hydraulic fluid starts to come out.
Screw the full syringe into the port on the caliper at the rear of the bike shown in the first photo.
Screw an empty syringe into the port at the front at the brake lever shown on the second photo. Fully depress this syringe before attaching it to the hydraulic system.
Push the stopper down on the loaded syringe until it is almost empty.
Remove the back syringe first. Depress the top syringe a little bit so that hydraulic fluid almost starts to flow out of the open hole. Then, replace the screw.
Once the first screw is replaced, remove the top syringe and replace that screw shown in the 2nd image.
Еще один человек закончил это руководство.
